looking for battery-less programmable thermostat info
Greg Durgin
Member Posts: 12
I would like to get some help finding thermostats for the following system and requirements:
System: hydronic heat (Peerless Oil) with mixed baseboard and radiant
Taco switching relay (SR506) (24V)
Heat only (though I have only seen heating/cooling units so far)
Replacing honeywell T87s (fed by two 18ga wires though there is a third wire avail at each location if that makes a difference)
Battery-less
Basically looking for these to be able to provide two settings per 24 hour period, seven days a week. Did I say battery less?
Thanks for any leads or technical feedback.
Warm regards,
Greg Durin
Battery-less
Warm regards,
Greg Durin
Batteryless thermostatic Valve actuator
Hi, Greetings from NZ, that paradise in the South Pacfic where it's summer time at present.
Heimeier from Germany make a 7 day programmable mains powered thermo head, I think it's called a 'E' and uses a programming card to program the head very simple looking. I have not ever used one (us poor Kiwis can't afford theses things) Could not find their web site. Their contact is 'Theodor Heimeier Metallwerk GMBH & Co.KG D-59592 ERWITTE Tel (02943)891-0-fax (02943)891-100.
Try our T8601 or T8000C
These stats provide 7 day programming, 4 periods per day.+-1 degree accuracy, lighted dial. Energy Star product. Our T8000C has fewer bells & whistles, and costs less but still will meet your needs, if you are on a budget. Available from any Honeywell distributor, or use the "Find A Contractor" feature above. For more info go to www.honeywell.com/yourhome/0 -
Thanks, Bill.
This is what I was looking for and even simpler.
I have six independent zones going in and am only looking for night setback on the heating. Don't need (or want) any bells and whistles. I came across info on the T8700C. This would be fine if it didn't have the cooling function and associated switches on top. Can the T8700C be mounted on a standard "Round" base? At least I could get rid of the cooling/fan/auto references.
Thanks for your feedback.
Greg0 -
thanks
Basic thermostat (to switching relay that controls circulators) was what I was looking for but thanks for the info on the programmable zone heads from Europe.
Greg0 -
A i tech therostat on an..
...old steam system. Do they work well. Iw as told the precion of new electrinic theromstats sometime causes havoc with an older vapor-vaccum system. Any thoughts?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
