AL29C vent connection failures
hot_rod
Member Posts: 26,645
seeing problems with the gasketed fittings? This was installed in 1999 on a Lochinvar boiler. The gasket rings crumble like plaster. I chose to replace the entire vent with the good old messy RTV silicone fittings.
Here I thought we were "out of the woods" after the original speced high temperature plastic vent materials disappered from the scene. Guess not!
hot rod
hot rod
the
ones I've been using have a orangish color seal. Seem pretty pliable so far..could it be that the mfr's have changed seal composition?
hotrod
Did you do a combustion test ? how hot was that flue??? Maybe overfired and cooked the gaskets?0 -
Let us know...
what the manufacturer says. I've not had occasion to pull any apart, but am sure it will happen eventually.
ME0
- 167 Indoor-Air Quality
