AL29C vent connection failures
hot_rod
hot_rod Member Posts: 26,644
seeing problems with the gasketed fittings? This was installed in 1999 on a Lochinvar boiler. The gasket rings crumble like plaster. I chose to replace the entire vent with the good old messy RTV silicone fittings.
Here I thought we were "out of the woods" after the original speced high temperature plastic vent materials disappered from the scene. Guess not!
hot rod
