advice on manual staple gun
Royboy2
Member Posts: 16
for a manual PEX staple gun. I have a top of the subfloor job and staples seem the logical (only) way to go. I'm happy to use a manual one given the frequency that I expect to need this tool.
Any tips on brand or sources to pursue (or avoid?).
Thanks, Royboy
Thanks, Royboy
Stapler
I haven't heard of any manual stapler that will work on wood. My manual stapler from Wirsbo is for foam insulation only with plastic staples. I looked all over before I shelled out the big bucks for my pneumatic gun to do the staple up and staple down stuff. As far as I know, they are a special crown width staple, ans a special nose piece on the gun to avoid stapling the tubing accidentally. I don't think you can get around it. You could use some sort of hammer-in or screw down type staple or clamp if you're real ambitious and find something suitable. Kevin0 -
good stapler
i like mine from peter magone co. it's a hand operated one.it uses R B 5 clips. their ph. # is 1-800-338-2448To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
hand stapler
Watts is marketing their version of the Mangone stapler. Works good if you think four or five pumps per staple is good.0 -
the one I've found
on the net at CPI (Consolidated Plumbing Industries) looks like the picture below and apparently shoots 1/2" or 3/4" staples. $40. Is this what Magone or Watts is selling?
Thanks - Roy0 -
the one I've found
on the net is from CPI (Consolidated Plumbing Industries) for $40. Apparently shoots 1/2" or 3/4" staples. Is this what Mangone or Watts is selling?
4-5 pumps per staple sounds kinda tedious, though ...
Roy0 -
Stapler
I have a Wirsbo pneumatic stapler that works great for staple down.I recently bought a Watts brand manual stapler to try on Aquapex and mine at least was apiece of junk.
John0 -
I believe Home Depot sells the Mangone stapler. I think it was around 30 -40 dollars.0
- 120 Geothermal
