Galv. pipe in hydronic systems with treated water
Gordo
Member Posts: 857
I've seen dark hints of problems caused when galv. pipe is used in hydronic systems with treated water. As I understand it, the zinc and the chemicals used for treating the water interact in negative ways. What are these problems, specifically? Would a 3/4" x 6" galv. nipple in a 500 gal. system be an issue? Thanks for your help.
Depends on the treatment
and what is blended in the conditioner. I know Dow cautions against the use of galvanized pipe of fittings, as the inhibitors in there glycols react with the zinc.
I imagine this could be the case with some hydronic conditioner fluids also.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
