Taco 007 Circulator Circuit Board on 009 circulator?
Chris Burt
Member Posts: 19
I have a 009 circulator and all it has electrically is the capacitor and the wiring for 110 volts. I would like to run the pump using a millivolt thermostat. Can I use the Electrical parts from a 007 on a 009 ? If this is not possible what is the correct way to run this pump on a single thermostat system. Do I need a 110 volt thermostat? Any technical help and a link to any relative literature would be appreciated
You need...
a Taco ZF series pump. It comes with an inernal transformer/relay set up already. Or, you could ppurchase any one of a hundred relay transformer packages that would do the trick. To the best of my knowledge, the 007 and 009 have different capacitors, not compatible. Could be wrong though...
ME
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
