Taco 007 Circulator Circuit Board on 009 circulator?
Chris Burt
Chris Burt Member Posts: 19
I have a 009 circulator and all it has electrically is the capacitor and the wiring for 110 volts. I would like to run the pump using a millivolt thermostat. Can I use the Electrical parts from a 007 on a 009 ? If this is not possible what is the correct way to run this pump on a single thermostat system. Do I need a 110 volt thermostat? Any technical help and a link to any relative literature would be appreciated
