How to Paint Steam Radiators
![[Deleted User]](https://secure.gravatar.com/avatar/9891462241e912628ece613b39a5f071/?default=https%3A%2F%2Fvanillicon.com%2F6cc0c65a30168d2dd6b720671b28722a_200.png&rating=g&size=200)
[Deleted User]
Hello: I just got done stripping the paint off my old steam radiators, all that is left is a bronze and silver paint. What type of paint can I use that will not crack off?
Someone mentioned Rustoleum "stops rust" has anyone tried this?
Thanks
Thanks
Painting rads
I would recommend having the rads sandblasted, as opposed to stripping (If you can get the rad out of the house). I use Rustoleum spray can primer (red oxide) then use Rustoleum spray can white. Over time, the white rad will fade to sort of a cream color.
To me, sandblasting is the best way to get off years/layers of paint, which BTW may be lead contaminated. Therefore, the sandblasting company handles disposal, instead of you and your household. Typically, I pay about $20 per rad with a 24 hour turnaround on blasting. Note: The rad must be primed within 24 hours to avoid oxidation.
I've had excellent results with this method.0 -
Painting rads
To me, sandblasting is the best way to get off years/layers of paint, which BTW may be lead contaminated. Therefore, the sandblasting company handles lead disposal, not you and your household. Typically, I pay about $20 per rad with a 24 hour turnaround on blasting. Note: The rad must be primed within 24 hours to avoid oxidation.
Radiator Paint
You may want to check out you local automotive store. Engine block enamel and exhaust manifold paints are made to take the heat. However color selection is somewhat limited.
Boilerpro0 -
Radiators were originally "bronzed" which is made by mixing bronze or aluminum powder with a bronzing liguid (varnish).
I'm not sure of the type of varnish. I have some in my basement as well as the powders.
I've never tried to use it.
I have used rustoleum aluminum and it covered great and held up well.0 -
Rads!
The suggestion of sandblasting is a great idea.One thing about painting the rads is you need to be careful of what paint you use.Outgassing may leave you with some foul stench for sometime.Engine block paint sounds like a good idea.But the best(not the cheapest) would be powder coating.Many of the sandblasting companies will also paint and or sandblast.
cheese0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
