Boiler emergency kill switches
Bryan_2
Bryan_2 Member Posts: 1
Controls and Saftey Devices
  • JimGPE_3
    JimGPE_3 Member Posts: 240
    Standard Building Code
    Is anyone familiar with a requirement to have an emergency boiler kill switch at boiler room exits? I refer to a "mushroom" type big button that will kill all boilers in the room when pressed.
    Specifically down south in the Standard Building Code/Standard Mechanical Code jurisdictions.
    If so, can you point me to where the requirement might be found?
    Thanks.
  • Bill Wright_2
    Bill Wright_2 Member Posts: 65
    Could it be ...
    that you are refering to CSD-1?
    It does require a "kill" switch (not necessarily a push button mushroom type) outside the boiler room door.
    CSD-1 applies to larger boilers (>400 MBH) and has been adopted in several southern states.
    Does this help?
    Bill Wright
    Manager, Radiant & Plumbing Systems
    Weil-McLain
  • JimGPE_3
    I don't recognize that acronym - CSD. Can you help?
  • Bill Wright_2
    CSD-1
    ANSI/ASME -- Controls and Safety Devices for Automatically Fired Boilers. A national code, that has been adopted by many states. Applies to larger boilers >400,000 Bth (does not apply to residential).
  • Bill Wright_2
    More CSD-1 info ...
    Here is a website:
    http://www.nationalboard.org/article3.html
    & I will attempt to attach a spreadsheet that lists all the states that have adopted CSD-1.
  • JimGPE_3
    Thank you everyone!
