steel compression tank
The tank has to be isolated from the water system; either chilled or hot water. Then drain the tank, close the drain valve and reopen the tank to the system. If the tank waterlogs, then you have a leak in the tank, the sight glass, the gage cocks, or the drain valve.If you lose the air cushion, it has to go somewhere. Use soap bubbles to detect the leak. Hope this helps.
