Magnaflow
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
I've seen these old circulators on a few job in our area....usually on radiant heating since they are high head, high volume; 3 amps. This one stopped working after almost 50 years of service.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Replacement
It can be tough to figure what kind of circulator to replace it with. This house only had one manifold and it was all 1/2" copper tubing going into the floor.
I chose a circulator with a flat curve - Taco 0010.
The job took me 2 hours last night after work (I'm slowing down as I get older); got done just in time to go vote. And yes, I know I installed the pump on the return, but this job will get a new boiler next year and I didn't want to do extensive re-piping only to rip it out later.
high head?
Did you feel that the original Magnaflow was too high head? The 0010 seems to be more of a low head, high volume pump.
I once considered it as a replacement for a B&G 100 to reduce operating cost (similar performance curves), but it draws about the same current so the savings didn't seem to be there.
Mark0 -
The Magnaflow
must've had a steep curve since I see it on jobs with old radiant done with a lot of 3/8" copper tubing. I think it was way overkill on this job; I figure no more than 8 gpm with 8-10' of head.
When I turned the system on, there was good flow thorough the boiler, a 20* temperature differential between the supply and return, no velocity noises and the boiler fired non-stop for as long as it took me to clean up my tools and get paid.
Man, was that old pump heavy!!
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
