Domestic hot water recirculator
Craig Patrizio
Member Posts: 17
Several months ago I remember researching a DHW 2-pipe recirculator that pumps the cool water from the hot water side back through the cold water pipe.. Does anyone remember this post and who makes it? I want to install one in my third floor bathroom.. wire it to the light switch or via a motion detector.. this way it's not always running.. but comes on when needed..
Thank you.
Craig
Thank you.
Craig
Does anyone remember.. or can recommend one.
Does anyone remember the hot water recirculator described above in the previous email.. or can you recommend one..?
Thank you.
Craig0 -
recirc
Grundfos makes several different pump setups for this!
Laing makes a recirc pump as well as Taco. Either site should contain the info you seek.0 -
Hot Water Recirc
Craig - The Grundfos Comfort System creates a hot water recirc loop using the cold water line as the return to the water heater. The pump is installed on the water heater, and it is controlled by a timer. The cross over valve is installed under the fixture furthest from the water heater.
If I did this correctly, the link to the website is http://www.us.grundfos.com/web/Download.nsf/DownloadViewOne/C88F78189A2792F888256B4B0067FB0F?OpenDocument. If I sent you off into cyberspace somewhere, send me an email, and I'll be glad to send you any information you need.
Thanks
Clint Andrews
Grundfos Pumps0 -
Re-circ
Taco does make one, we call it the plum n' plug with a timer and aquastat. I also recommend the Metlund system, it is truly the best out there! Check it out at www.gothotwater.com.
- Mark at Taco0
- 50 Industry Classes
