aqua-booster piping
Al_12
Member Posts: 21
I need a piping diagram for an aqua-booster set-up. I am looking to tap off a 5-gpm coil on the boiler for extra hot water storage. thank you in advance.
aquabooster piping
i have the info you need do you have a fax number?0 -
booster piping info
Maybe you can post it here for all to see?
aquabooster plumbing
i would post the info but cannot get scanner to work im willing to fax the info to someone who could than post it0 -
fax me
Ed,
I tried to email you but the email address you post with here doesnt work. Email me and I will give you my fax number. We'll need to coordinate when you fax the diagram so I can turn on my fax software. Then I'll scan it and post it on the wall.
Phil
We have transmitted and
converted to file.I have plenty more where that came from thanks to Ed Wallace!Let me know if this is not enough.
cheese0 -
thanks mike
thank you for your help i also faxed to phil white walkgood phil thanks for the help still learning to use this technology you are a good guy to know0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
