aqua-booster piping
Al_12
Al_12 Member Posts: 21
I need a piping diagram for an aqua-booster set-up. I am looking to tap off a 5-gpm coil on the boiler for extra hot water storage. thank you in advance.
  • ed wallace
    ed wallace Member Posts: 1,612
    aquabooster piping
    i have the info you need do you have a fax number?
  • Patchogue Phil_2
    Patchogue Phil_2 Member Posts: 316
    booster piping info
    Maybe you can post it here for all to see?
  • ed wallace
    aquabooster plumbing
    i would post the info but cannot get scanner to work im willing to fax the info to someone who could than post it
  • Patchogue Phil_2
    fax me
    Ed,
    I tried to email you but the email address you post with here doesnt work. Email me and I will give you my fax number. We'll need to coordinate when you fax the diagram so I can turn on my fax software. Then I'll scan it and post it on the wall.
    Phil
  • Mike Kraft
    Mike Kraft Member Posts: 406
    We have transmitted and
    converted to file.I have plenty more where that came from thanks to Ed Wallace!Let me know if this is not enough.
    cheese
  • ed wallace
    thanks mike
    thank you for your help i also faxed to phil white walkgood phil thanks for the help still learning to use this technology you are a good guy to know
