Water Heaters & Hot Water Heat
Chris Schreel
Member Posts: 2
I recall reading an article about utilizing a domestic hot water heater in lieu of a traditional hot water boiler for hot water radiant heating. Could you please refresh my memory and point me in the direction of such articles.
I have an existing house undergoing renovation, which includes replacement of a steam boiler and the addition of air conditioning. I was considering utilizing an extremely high efficient water heater to provide 140 degree water for space heat. Again, any articles that you are aware of would be greatly appreciated.
Chris Schreel
Applied Mechancial Systems Inc.
5598 Wolf Creek Pike
Dayton, OH 45426
Tel: 937.854.3073
Fax: 937.837.6429
Chris Schreel
Dayton, OH 45426
Tel: 937.854.3073
Fax: 937.837.6429
Code
One issue that has come up is the code requirements for heating appliances. Does the code where you are require heating appliances be ASME certified?0 -
We install ASME certified accessories above 200,000 Btuh. Typically we install the AO Smith Cyclone BTH-199 with individual expansion tanks to stay away from ASME ratings.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
