I lost it!
Mark Eatherton1
Mark Eatherton1 Member Posts: 2,542
that neither of those bays has any representation of insulation in it. That changes every thing.
ME
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=88&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    need some information
    A while ago, someone posted a picture or two of an infrared comparision picture of using plates versus not using plates. I thought I had saved it, but can't find it.
    Can someone please re-post it or send me a link? I recall that Siggy had done the research and this was a repost of it. I could be wrong on that, though.
    Thanks.
  • hr
    hr Member Posts: 6,106
    This article
    Raised some blood pressure in the industry :)
    http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,80254,00.html
    Try Dale at Radiant Engineering. He has some FEA graphs comparing output differences also.
    hot rod
  • Jeff Lawrence_24
    Thanks.
    Thanks Hot Rod. That was the article I wa looking for, but I need the infrared picture that does the comparision between plates and no-plates.
    J.
  • Jeff Lawrence_24
    I found it!
    The last stinkin' disk I found in a pile in the back of a drawer in the desk had what I was looking for.
    Thanks.
    J.
  • jim f
    jim f Member Posts: 182
    INSULATION
    on the left side of the chart says 4" fiberglass insulation on both comparisions
    jim f.
  • how would the infrared picture look
    if there were 4 pipes in the staple up bay. bob
  • bruce pirger
    bruce pirger Member Posts: 111
    Forwhatever it's worth...I think those pictures are results of models, not true an actual images. However, they are probably pretty accurate. (I could be wrong...but sure likes like a model output to me)
    More tubes I'd think would be just what you'd expect...4 "peaks" and corresponding valleys. Lower temp water could be used.
    Are you considering 4 tubes in a 16" joist bay? 4" on center?
  • i do install
    my staple up 4" on center near the outside walls. i feel i get a lot more heat output that way. bob
  • Larry Ticknor
    Larry Ticknor Member Posts: 38
    I would question
    how accurate that picture is because it shows the btu's traveling further into the insulation than into the plywood. I use an R-value of about 1.2 per inch for plywood and 3.5 per inch for fiberglas insulation. If the R-value has anything to do with the heat movement, it should be traveling faster through the plywood than the insulation. But maybe I'm missing something.
    Larry Ticknor
