I lost it!
Mark Eatherton1
Member Posts: 2,542
that neither of those bays has any representation of insulation in it. That changes every thing.
ME
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=88&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
ME
need some information
A while ago, someone posted a picture or two of an infrared comparision picture of using plates versus not using plates. I thought I had saved it, but can't find it.
Can someone please re-post it or send me a link? I recall that Siggy had done the research and this was a repost of it. I could be wrong on that, though.
Thanks.0 -
This article
Raised some blood pressure in the industry
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,80254,00.html
Try Dale at Radiant Engineering. He has some FEA graphs comparing output differences also.
hot rod
Thanks.
Thanks Hot Rod. That was the article I wa looking for, but I need the infrared picture that does the comparision between plates and no-plates.
J.0 -
I found it!
The last stinkin' disk I found in a pile in the back of a drawer in the desk had what I was looking for.
Thanks.
J.0 -
INSULATION
on the left side of the chart says 4" fiberglass insulation on both comparisions
jim f.0 -
how would the infrared picture look
if there were 4 pipes in the staple up bay. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Forwhatever it's worth...I think those pictures are results of models, not true an actual images. However, they are probably pretty accurate. (I could be wrong...but sure likes like a model output to me)
More tubes I'd think would be just what you'd expect...4 "peaks" and corresponding valleys. Lower temp water could be used.
Are you considering 4 tubes in a 16" joist bay? 4" on center?0 -
i do install
my staple up 4" on center near the outside walls. i feel i get a lot more heat output that way. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
I would question
how accurate that picture is because it shows the btu's traveling further into the insulation than into the plywood. I use an R-value of about 1.2 per inch for plywood and 3.5 per inch for fiberglas insulation. If the R-value has anything to do with the heat movement, it should be traveling faster through the plywood than the insulation. But maybe I'm missing something.
Larry Ticknor0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
