Tomorrow is the big day!
Chris_4
Member Posts: 75
taking the master plumbers test tomorrow!
any tips?
won't know if I passed after the test, they are not taken on computers here.
Chris
any tips?
Chris
Good luck.
Hope you pass.0 -
tips
Relax and show your stuff! You'll do fine. If in doubt, oversize the drain or vent one pipe diameter. Add as many code numbers as possible & if there's a place where the waste arm is borderline before needing re-venting, state the length on the drawing and reference the code number that deals with max lengths.
Don't forget to put DFU's on each fixture.
So what's the trick question to be? Garage drains? Perhaps an acid neutralizing station(G).
G'luck!
Good Luck
Good luck fellow tradesman!
Don't forget
about pipe sizing and 2.5" pipe. It will get you every time, even if nobody uses it. GOOD LUCK!0 -
Best of luck Chris
Your post reminded me of my exam in the early 70's. You'll be reminiscing about yours one day also. Just relax, read the questions through, answer those your sure of first and then go back. One last thing, when in doubt go with your first instinct.0 -
thanks for
the tips and good words everyone!
took the test this AM. first section before noon, second section after noon. wasn't an easy test, but I think I passed........will find out in about three days with the "unofficial results" and recieve the "official results" in about 2 weeks.
hate waiting!!!
Chris
Chris0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
