Indirects HWHeaters: tank-in-tank vs. coil-in-tank
Doug_3
Member Posts: 14
I am looking at high quality versions of both types. The heat exchanger in the coil-in-tank model I'm looking at is stainless steel and the coil runs throughout the stainless steel tank (it isn't just a sitting at the bottom of the tank). The tank-in-tank model features a stainless tank of domestic surrounded by a bath of boiler water. Both models have similar specs. What's your opinion?
Tank in Tank
All I use!
Mark H
indirect
mark why only tank in tank0 -
tank
in tank man myself. Not much pressure drop to worry about, lots of heating surface, scale resistant..
I post too fast
I should have said I use Tank-in-Tank 90%+ of the time.
I do use Buderus LT series tanks when I am installing Buderus oil boilers.
As others have mentioned, the pressure drop across a tank-in-tank is less and there is a huge heat exchange surface.
Throw in stainless steel as an added bonus and it's a pretty easy decision for me!!
Mark H
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
