Expansion Tank Vent
Wayco Wayne
Member Posts: 615
I found out several years ago at a seminar run by some guy named Dan Hulahoop* that when you check the pressure on an expansion tank with an air bladder there should be no pressure on the tank on the water side while your'e checking. I started isolating the tank with a ball valve with a waste vent on the tank side so I can shut off the tank, bleed the water pressure and check the air in very short order. Is this a common practice? Makes sense to me. *(Is it appropriate to poke fun at our benevolent hosts name?)I just got my digital camera working again. I'll try to send a picture
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
I do it that way, WW
and have never had a problem.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Nice idea & photo.
Question how did you get that huge camera in the house? Most folks buy a small hand neld one. That bill board sized photo is wild! anyway bigugh0 -
thats what i do
i do remove the handle from the ball valve to try and keep it as safe/tamper proof as possible.0 -
It's Hooligan...
not Hanigan!!
Mark Earthington
That's
right. Look no further than Word spell check!Retired and loving it.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
