steps in sizing hydronic circulating pumps
steve curran
Member Posts: 6
I want to know the the method on sizing of circulating pumps for hot water heating. commercial and residential.also the question which is better putting circulator in supply side or return side of hydronic system
You need to know
how much water you have to move, and what resistance ("head") the pump has to work against. Then you can pick your pump by looking at performance charts for different pumps.
If you're working on a gravity conversion, it gets a bit more complicated. Paste this link into your browser and follow it to a real good ;-) article on the subject. It pays to wander off the Wall!
http://www.heatinghelp.com/newsletter.cfm?Id=125
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Baltimore, MD, USA
Consulting0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
