Honeywell Outdoor Reset Control
JTel
Member Posts: 12
Anyone out there ue this control (AQ475)? I had a problem with the ten second circulator "post purge" dead heading my pump against my 2 zone valves. Also the pump exercising feature of the control looks like it will be a problem too. Honeywell tech support had no answers for me...
need a bypass
not for the heart, but for the exercise! in our regulations, it is stated that any time a circ can run when there are no zones open, a pressure relief bypass (or whatever you call em in your neck of the woods) must be installed. before this we use to just use a throotled bypass.
leo g0 -
AQ475
The circ exercising mode is automatic, and runs the circ pump for 10 seconds every 72 hours to help prevent the pump from seizing up during the summer months. I'm not sure what you mean by a "10 second postpurge". The piping should include a pressure relief bypass to prevent deadheading the pump against closed valves.0 -
10 seconds
I don't see any mention in the documentation that this control does a post purge - perhaps it an undocumented feature?
I know running a pump dead-headded is a bad thing, but will 10 seconds every 72 hours be enough to cause a problem?
Mark0 -
Maybe "post purge" was the wrong phrase. With this control after the thermostat satisfies, the circ. will run for ten more seconds to give off excess heat in the loop. When my tstat satisfies the zone valve closes but the circ still runs for 10 seconds everytime. But i guess bypass is the way to go, but i think honeywell should tell you that in their installation manual. My other option is to wire all of my heat zones into a seperate relay box and not use the honeywell relay on the aquastat. This way the pumps will run and shut down "normally".0 -
AQ475
I will pass that on to the marketing guys for the next revison of the cut sheet. Thanks for using Honeywell products!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
