oxygen barrier
bovide
bovide Member Posts: 13
I want to replace steam return lines with 1" pex tubing. Because a steam system (one pipe) is vented, do I need to bother with oxygen barrier tubing, or can I use potable water pex?
  • Senator
    I think I would stick with iron pipe. Sagging would be a problem, even if it COULD take the heat.
