oxygen barrier
bovide
Member Posts: 13
I want to replace steam return lines with 1" pex tubing. Because a steam system (one pipe) is vented, do I need to bother with oxygen barrier tubing, or can I use potable water pex?
Senator
I think I would stick with iron pipe. Sagging would be a problem, even if it COULD take the heat.
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
