European heat - Scott
ScottMP
ScottMP Member Posts: 5,882
So since I was in Belguim and this IS a heating sight, I checked out the heat as much as I could. This photo is the panel rad. in my hotel room. Almost everyone I checked out had a panel rad with thermostatic valve. The heat was not on when I got in the romm but came on that night. Don't know if it was WWSD or just a switch that the hotel operated when they felt it was cold enough. Saw a couple of Danfoss valves the others I could'nt tell the name.
Only saw one house that had cast iron radiators. Oddly enough in a very old town.
My nephews house that he stayed in had a new boiler, oil fired with riello, did'nt know the name but looked like Viessmann. All manifolds with panels rads and TRV's ( these had bypass valves ) All the pex was run in colored sleeves. Red for feed and Blue for returns.
Saw a number of Viessmann signs and a Buderus plant ( no time for a tour :( ).
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
