arco cast iron convector
Steamhead
Member Posts: 18,218
the depth of the enclosure, the height and the length. Then if you can't find the exact unit, locate something that's close (doesn't have to be the same manufacturer). Often this will be close enough that you can use it without problems.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
another mystery..In Dan's "EDR" I find ratings for Arco C/I convector, the thinnest listed is 5 3/8. I assume this is for a 3 section. Many of the rads in this house are 2 section, and I'm looking for EDR for these..anyone?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
