arco cast iron convector
Steamhead
Member Posts: 17,341
the depth of the enclosure, the height and the length. Then if you can't find the exact unit, locate something that's close (doesn't have to be the same manufacturer). Often this will be close enough that you can use it without problems.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
another mystery..In Dan's "EDR" I find ratings for Arco C/I convector, the thinnest listed is 5 3/8. I assume this is for a 3 section. Many of the rads in this house are 2 section, and I'm looking for EDR for these..anyone?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
