A friend called me
Steamhead
Member Posts: 18,218
S.T. Johnson, that is. They also made boilers with top-mounted burners, but their original burners were standard high-presure units.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
a friend called me
and wasnt quite sure what he was looking at. All he could say for sure was it had an oil burner on it. He was looking to do a replacement boiler. But didnt know what he was into.
Chuck Shaw
name
Is that a G.E.?0 -
It does
look like an old GE with a replacement burner. I had one feeding my radiant heat until my service tech retired and I couldn't get it repaired. Just before replacing it the master control used to stick and in the middle of the night, 50 degress in the house, I would go out and move the switch to start it up. They were very popular in the upscale sections of Worcester, Ma. My late Father-in-Law used to work for a company that sold replacements because the tankless attachements used to leak. He'd pull them out, weld the areas that leaked and then reinstalled them in friends houses. They were amazing units.0 -
With Clothes
on. Still going. Started in 1946
I always get a high stack and a trace of smoke. Never cool and clean.
Just out of warrantee!
al0 -
looks like a couple of cans of r-12 in corner.0 -
whats
the apple sticker on the front,oil company info?0 -
apple sticker
I have one customer with a boiler like that. the first time i saw it idid not know where the burner was. No gas pipe. Then i took off the top cover & there was the oil burner firing down. It uses a lot of oil. A good canidate for new equipment.0 -
R-12
Emptys
al0 -
Apple sticker
Right, Apple oil CT.
To get the oil acct. they do an free efficiency test, it includes the sticker.
al0 -
A good canidate
It probably kept some Shake and his family going during it's 56 years. This is it's (sshhh) last year.
It's not that bad, you need to keep the donut at the bottom clean. Just like brushing out a cast iron boiler except the fire is on top.
It was converted to a Carlin in the 70's
It takes care of 3400+ sq ft. The phase 111 saves $$
al0 -
Whatcha..
going to replace it with? I won't tell the GE...promise. kpc0 -
Whatcha..
Kevin,
Ok here's the story up to now. I have a Dunkirk boiler, I inherited from one of those infamous McMansion renovations on a partial tear down, complete with a Bekett AFG. After I clean it up and test it I will know.
If it's ok, put in a new chamber and that's the boiler. The heating system is CI rad. monoflo on one zone & base board on the other.& A phase 111. It will have secondary/primary with variable speed injection. With all the stuff, including the chamber, I will have approx 400. tied up in parts. This is in a rental unit.
al0 -
Nozzle assembley
is tuff to get out when it slips down the blast tube on those Carlins, seen them with Becketts and Riellos. Still a few of those GE's kicking around in northern CT.
Joe0 -
southern ct. also. (bridgeport area) i know the feeling of dropping the gun down. most of these ran on the original burners with a 1/2" overhead 1 pipe oil line. anyone remember the "timken"sling shot with the wick?? now that was a good burner!!0 -
What a great
picture. Do not get rid of it. They were way ahead of their time and time still hasn't caught up. I wish I still had mine.0
- 167 Indoor-Air Quality
