I would like HTP
hr
hr Member Posts: 6,106
(mothership of the Munchkin) to offer a couple sizes of insulated buffer tanks with 1-1/4" tappings. A bunch of them as well as some 1/2" taps for gauges and wells.
Then--- offer a mounting kit to set the Munch on top! This would solve a bunch of issues. A good solid mount for the Munch, puts it at a better level for service and adjusting, gives you the buffer feature, and occupies a small foot print.
The buffer could also be an indirect, should the job require DHW.
Oh, and make the bracketing out of some nice stanless in the rare, unlikely even of a leak some day.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Home Depot
    sells a heavy duty shelving system that we use for Munchkin installs; I know you guys must laugh at me, but hey, you can stand on these.
  • munchkin-man
    munchkin-man Member Posts: 247
    Munchkin brackets
  • munchkin-man
    Munchkin brackets
  • munchkin-man
    Munchkin brackets/shelves
    we are looking into a few different ones and will be decideing on if we will be ofering them in our catalog or just recomending afew different types and where to get them I will keep all posted
  • corey
    corey Member Posts: 45
    Code?
    My plumbing inspector would not let me put the Munchkin on a stand, even an extremely beefy 1000 lb+ capacity all-steel stand that I fabricated just for this purpose. Growl.
    "I want concrete blocks!", said he...
  • corey
    Code?
  • Gregg Jackson
    Gregg Jackson Member Posts: 55
    munchkin stand
    I was thinking about using these out of the Hodesco catalog. They say it will hold up to a 50 gal water heater. That should be about 400 + lbs.
  • Paul Cooke
    Paul Cooke Member Posts: 181
    Munchkin Stand
    I've used that very stand with the 80M Munchkin a couple of times. It looks nice and is plenty strong. I like having them up off the floor because it's easier for servicing.
    Alan, your wall-mounted bracket looks like it works great. A piece of metal coated plywood for the base would be a nice addition.
