One pipe steam radiator valve
Scott Toenniessen_2
Member Posts: 14
Thanks for the info everyone. Your advice led me to one and I have ordered it.
- Scott
- Scott
Hey,
I don't have my Lost Art... handy as I'm at work and I'm not sure this answer is in it anyway. I need a straight radiator shutoff valve for one pipe steam radiator. The angle ones are the only type I can find. I did find a globe style radiator valve but I realize it is going to trap water in the radiator (must be intented for two pipe steam or hot water). Any suggestions? Just a standard gate valve? I was hoping for an authentic radiator valve for appearance sake and also since the union is part of the valve. With a gate valve I need to add a union using a couple of nipples and the thing will just look ugly.
- Scott
Radiator Gate Valves
You're right, Scott- a straight globe valve is not the answer. They used to make gate valves with radiator unions on them. I'm not sure if anyone still does, but it can't hurt to look.
If you can't find one of these, an ordinary gate valve and union will work fine.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Baltimore, MD, USA
Consulting0 -
1/2, 3/4 or 1\" are available
with the union on them. call 202-667-6500. C0 -
Try
www.statesupply.com0 -
Just bought two of them at Home Depot. I believe you can also find them at the website of Legend Valves and Durst. The one I bought at Home Depot are Durst made, I believe in NJ?
Valve was @ 12.000 -
Radiator Valves at Home Depot
Wish I had an answer. The ones at Home Depot are imported from the Pusan Pipe Company in China and are junk. The gates fall off them if the casting is not full of sand holes.
It may be your only choice; as most on-line venders only sell the Chinese stuff also, except they charge American prices.
Good luck.
Ed0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
