Vaporstat Setting & Boiler Operation
Dave_23
Dave_23 Member Posts: 190
Folks,
In my vapor system, I will be substituting a L408A1132
vaporstat for the stock pressuretrol.
It was recommended that I start with the following vaporstat settings: Cut in at 4 oz, Differential at 6 oz.
Given that this is a subtractive type device, is the following operating profile correct:
Upon call for heat, the boiler steams to a maximum of 10 oz pressure, at which time, the boiler shuts off. When the steam pressure drops to 4 oz, the burner refires. All this is assuming that the thermostat is continuously calling for heat.
Correct?
-Dave
  • yes
    see if all of the radiators still get hot and if so, that's all there is to it.
