Wine cellar temp/humid control- does Bean have a panel?
Tom
Tom Member Posts: 1
I have a project that has two forced air systems and the customer is putting in a wine cellar, he wants to control temp and humidity.
Have any ideas?
Try our fax 717-840-9398.
Thanks yalll....
  • don_9
    don_9 Member Posts: 395
    wine enthusinst
    Tom,checked out www.breezaire.com,they will be able to help.
    Check out the wk3000 units,I have installed a couple.Be
    careful around those $15.000 dollars wine bottle,If you break one you will be doing the job for free, been there done that,ouch!!!!
  • todd s
    todd s Member Posts: 212
    Wine Cellar
    Try www.cellarmate.com I saw this in Contractor magazine this looks like a simple unit.
  • Jamie Pompetti
    Jamie Pompetti Member Posts: 82
    Tom
    I am going through the same problem you are right now! We looked into the breeze-air systems and other "wine" cellar systems. The big problem is parts.......... These companies are great up front but how fast can you get parts?
    So I went to United Refrigeration and we decided to use a commercial refrigeration system..
    We are going to use a walk in freezer evap (because it has a heating element in it) and a t-stat and a humidistat!
    Please let me know what you are going to us. Knowledge is power!
  • JIM F.
    JIM F. Member Posts: 82
    wine cellars
    i have done a couple of wine cellars. i have to agree with some of the previous posts about part availability. the self contained units are nice because you just slip them in the rough opening and plug it in. the sensor is actually located in the mouth of an empty bottle of wine placed on the shelf filled with water. another system we installed is a refrigeration unit as posted previously and a carrier variable speed air handler with electric heat controled by a carrier thermidistat(temp-humid control). recomend using a txv not a piston. make sure if you go this route you research the line voltage wiring. got a little tricky!
    good luck
    jim f. milford, ct.
  • RB_2
    RB_2 Member Posts: 272
    Like the others have said...
    those premade wine coolers are...well...very cool.
    Would have to agree with the comments listed here.
    Thanks for thinking of us!
    RB
