Trianco D-max boilers
Cosmo
Cosmo Member Posts: 159
I installed a trianco d-max boiler in the winter of '99. Had a few problems, the quick-connect plug for the burner was defective-one of the pins was never installed. The other is ongoing....the termination outlet (side wall kit that comes with boiler package-balanced draft type) keeps leaking from exhaust to intake. The first year I took the termination fitting back to supply house and they gave me a new one...said that the factory didn't use the right silicone, since then I have to replace it every year under warranty. The exhaust temps are normal- 375-400degrees F. Has anyone tried using another brand of term. fitting thru the wall? I am tempted to buy a side-shot from tjernlund....
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Oh my goodness!!!!!
    > from tjernlund....
  • Joannie
    Joannie Member Posts: 99
    D-Max
    Laars bought Trianco back in 1998. I can get in touch with the right person to help you, so I've emailed you.
    Joannie Mishou
    Laars Heating Systems
  • kevin
    kevin Member Posts: 420
    Casmos......
    is this one of those deals that has a combined intake under the exhaust in one hood?????? I have had some problems w/ that in other brands. I now only use thw Aerocowl style that Buderus has and seperate the two terminations.kpc
  • Cosmo
    Thanks Mark
    You know I replaced this last year and I never recieved the $120. My supplier never told me. Today I picked up the second replacement termination fitting, this one is welded stainless steel. The last two were put together with silicone. Lets hope this works!
  • Cosmo
    It is a Beckett AFII. I wish the AFII came with the honeywell R718A burner control, I every Beckett burner would come with that standard!
    Casmos Valavanis
    Dependable P.H.C. Inc.
    dependablephc@enter.net
