Lennox
GW
Member Posts: 5,135
hello,
Is the Lennox HSW4-261-1FFP a two ton? How about a -211- ??
Thanks,
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=171&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks,
Gary
Lennox A/C Model numbers
> hello,
> Thanks,
> Gary
> _A
> 171&Step=30"_To Learn More About This Contractor,
> Contractor"_/A_
Gary, the middle numbers of all Lennox units run like this:
-211- = 1½ ton
-261- = 2 ton
-311- = 2½ ton
-411- = 3 ton
-461- = 3½ ton
-511- = 4 ton
-651- = 5 ton
Also, if the last number is a 3 intead of a one the unit is 3 phase (-263-).
So to answer your question, the unit you have IS a 2 ton unit.
Hope this helps.
Glenn0 -
-211- = 1½ ton
-261- = 2 ton
-311- = 2½ ton
-411- = 3 ton
-461- = 3½ ton
-511- = 4 ton
-651- = 5 ton
Hope this helps.
Glenn0
