Lennox
GW
GW Member Posts: 5,137
hello,
Is the Lennox HSW4-261-1FFP a two ton? How about a -211- ??
Thanks,
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=171&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    Lennox A/C Model numbers
    > hello,
    > Thanks,
    > Gary
    > _A
    > 171&Step=30"_To Learn More About This Contractor,
    > Contractor"_/A_
    Gary, the middle numbers of all Lennox units run like this:
    -211- = 1½ ton
    -261- = 2 ton
    -311- = 2½ ton
    -411- = 3 ton
    -461- = 3½ ton
    -511- = 4 ton
    -651- = 5 ton
    Also, if the last number is a 3 intead of a one the unit is 3 phase (-263-).
    So to answer your question, the unit you have IS a 2 ton unit.
    Hope this helps.
    Glenn
  • Glenn Harrison
    -211- = 1½ ton
    -261- = 2 ton
    -311- = 2½ ton
    -411- = 3 ton
    -461- = 3½ ton
    -511- = 4 ton
    -651- = 5 ton
    Hope this helps.
    Glenn
  • GW
