High Pressure Boiler Blowdown Separators
Leonard Weiss
Member Posts: 4
Would appreciate information about New York City and/or ASME requirements for blowdown separators with high pressure boilers. I need the actual code sections. Thank you.
Leonard Weiss
Leonard Weiss
BD Seperators
I suggest that you reference the National Board of Boiler and Pressure Vessel Inspectors publication...National Board Rules and Recommendations for the Design and Construction of Boiler Blowoff Systems, NB-27. Also, ASME Section VII...Recommended Guidelines for the Care of Power Boilers.
In our area, non-code blowdown seperators(BDS) are accepted but if the boiler installation system is "professionally engineered", it is likely the BDS will be ASME stamped.
I further recommend that if you have insurance on the boiler that you contact your boiler inspector for input or go directly to the appropriate jurisdictional office for help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
