Weil busts a move hr
hr
Member Posts: 6,106
Hard to know which "new" products to trust. We all have memories of lifetime warrantys and "bad batches" of tube runs.
I don't have a good answer to your questions. Who to trust that the product is suitable for long term applications.
I'm still of the opinion a third party testing facility should test and rate various radiant components. Like the IBR ratings on boilers and baseboard.
I feel the RPA could be a vechicle for this. Unless of course, you are comfortable with the manufactures testing :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
and offers
This sweet S.F.I. fitting and tool one nice, simple, swivel fitting fits all types of pex. Also a new pex where the O2 barrier is sandwiched in the middle of two pex layers.
What's next? A condensing boiler?
hot rod
Pex-Al-Pex
I recently viewed a photo a contractor sent me of some Barrier pex tube from Wirsbo that had been installed over a dozen years ago. At that time Wirsbo had laminated the barrier on the tube with a different process and it had begun to delaminate over the course of years. Are these laminating methods tried and true for Pex-Al-Pex? I know as our industry heats up,(pun intended) Tubing companies are going to come out of the woodwork.
Paul
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
