I love this toy....
Cosmo
Member Posts: 159
I made a bunch of cuts already, but only a couple that we actually for the job!! Why did we take so long to have this? Thanks to the wallies Hot Rod, Mark E. and friends....
Cas
Cas
Looks like
achop saw to me. What kind of blde does it have??0 -
Not abrasive...
It is a 14" carbide tipped steel blade. I could'nt believe it, cuts through tough rebar as if it was a carrot!
Cas0 -
What model is this tool
How long does the blade last? How expensive are the blades? Where did you buy it and how much did you pay? Thanks for any info in advance. Wayco Wayne0 -
model and price info
I got my info right here on the wall. M.E., and Hot Rod had posted about it and I had to have it! Dewalt Model#DE872. They got their's via mail order. Try www.amazon.com and look for the tool section. Also www.toolking.com, deals were $389, including two blades. I bought mine at my local tool supply house, they gave me the same deal. I always try to give my local businesses first crack. The blade is said to last for approx 1200cuts, but it depends what you cut. I was using it today, cut 3/8 threaded rod, 2x4's, pvc pipe, and unistrut. Works great, no grinding off burrs if you take it easy cutting. I should get a comission for advertising it!
Cas0 -
I was thinking it would be good
for cutting radiant tral plates. Got a big plate job coming up and can't imagine using a sawzall0 -
It
cuts them very well.Once you have one you will find many uses for it.
Hey, I couldn't reply to your email.....
What was the problem? Anyway I think you got the answer here.
Cas0 -
Yep
Got all I need. Tool King seems to have the best price. Cheke dGraingers and Amazon, both high. Thanks again Wayco Wayne0
- 167 Indoor-Air Quality
