Reset Button
Bill_4
Member Posts: 16
Ive got to push my reset button on the primary about once a month.Ive replaced the cad cell and the primary(Aquastat),and the boiler is clean as well as all the filters,any suggestions?
does this happen every time you get a fuel delivery?0 -
Bill
Do not just replace controls for the sake of replacing them.You must start somewhere and test each control with a meter or a gauge.I do not know if you are a homeowner but if you are please let a licensed oiltech check your unit out for you.If you would like someone in your area email me and I am sure I can get someone that can help you.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 855 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
