Info on boiling water at altitude
Unknown
Member
Check this out. I like the part about checking altitude with a thermometer.
http://hvac-talk.com/vbb/showthread.php?threadid=21105
Noel
Noel
Okay, I'm missing the point....
Given that there is a direct correlation between altitude and atmospheric pressure, and thus the temperature at which water boils, you can read altitude using a thermometer, a pot of water, a fire and some math, to a pretty good degree of accuracy.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
