Info on boiling water at altitude
Check this out. I like the part about checking altitude with a thermometer.
http://hvac-talk.com/vbb/showthread.php?threadid=21105
Noel
  • JimGPE_3
    JimGPE_3 Member Posts: 240
    Okay, I'm missing the point....
    Given that there is a direct correlation between altitude and atmospheric pressure, and thus the temperature at which water boils, you can read altitude using a thermometer, a pot of water, a fire and some math, to a pretty good degree of accuracy.
