placement of VXT-120 water feeder on a Weil-Mclain steam boiler
John McCarthy
Member Posts: 2
HELP!!,,where do you locate the control and the waterfeed manifold on a Weil-Mclain steam boiler?,,is it critical?
Thank You,,,John
Thank You,,,John
placement of a waterfeeder on steam boiler
SGO4 boiler and VXT120 automatic water feeder0 -
Water feeder
I must ask why do you need one? Small system like this might only need water monthly if tight, gives good reason to check boiler. I've found on small systems like this can over fill system over ashort time with auto-feed.0
- 167 Indoor-Air Quality
