placement of VXT-120 water feeder on a Weil-Mclain steam boiler
HELP!!,,where do you locate the control and the waterfeed manifold on a Weil-Mclain steam boiler?,,is it critical?
Thank You,,,John
  • John McCarthy
    John McCarthy Member Posts: 2
    placement of a waterfeeder on steam boiler
    SGO4 boiler and VXT120 automatic water feeder
  • John@Reliable
    John@Reliable Member Posts: 379
    Water feeder
    I must ask why do you need one? Small system like this might only need water monthly if tight, gives good reason to check boiler. I've found on small systems like this can over fill system over ashort time with auto-feed.
