vapor system
don_9
Member Posts: 395
Any chance on getting new orfices for rads after someone
has replace valve.Got a steam system that has lots of problem.
don
don
nope
You're going to have to make them.
Noel0 -
Heat-Timer
was selling them at one point, but I'm not sure if they still do. Worth a call.Retired and loving it.0 -
I can get them in the Baltimore area
don't know who makes them, but I can find out. We got a bunch of 1/2-inchers for that orifice system we're working on. We had to drill them ourselves but that's not a big deal.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Thanks guys
I got two apartment building side by side,one apartment has
the vapor system,the other has a one pipe parallel-flow
up-feed system.Other then the orfice problem the vapor system is not to bad.But the one pipe is a nightmare,copper
headers,near boilerpiping copper not enough A DIMENSION
end of steam main copper with copper riser no drips or
water seal.If I could Learn how to put pics on the wall
You won't believe your eyes.0 -
orfice
Dunham / Bush (MEPCO) makes an Adjustble orfice steam radiator valve. It has an adjustable stem that prvents the valve from opening farther than the set point. Works great! your biggest problem is knowing what size orfice you want. With the D/B valve you can play with it until you find the sweet spot. Try your D/B rep or State Supply.
http://www.statesupply.com/default.cfm0
- 167 Indoor-Air Quality
