geothermal question
bill_8
bill_8 Member Posts: 15
installing a water to water geothermal system to drive floor radiant heat and provide full time DHW. My plan is to use electric water heaters as storage (and emergency heat). This will be installed in a crawl space area that is about 60" or so tall. I'd like to find an electric HWH about 45" high or so that is well insulated and in the 50 gallon + range. Any suggestions? Also, what would be the best way to install an aquastat in the tank?
