residential steel boilers.
BOB_23
Member Posts: 19
I would like your opinion on what steel oil boiler is the better boiler. one that is negative fired or positive fired?
lets hear from the experts you the installer and service men and women.
thanks bob eck
thanks bob eck
Steel boilers
Burnham LE is one of the better ones,
also axeman andersen.But I still would install a cast iron boiler if possible.Most cast units will last at least 35yrs. if maintain.Seems like most steel boilers I see after 20 yrs look it. Hope this helps.0 -
I like to...
use Thermodynamics. Esp the LM series. It is wet based, built in air scoop,good warranty compared to others,competively priced, available w/ many burners(Carlin, becket, riello...(READILY),The burnham LE is is not. lower mass for those who like that. There S series is also good w/ 5gpm tankless coil as is their CWL model for a lower profile wet leg set up. I have used all 3 and no its not a Buderus. Where people(HO and Contractors) can't see value they are a good alternative.
Its been a while since I used one but the olympus boiler by axman-anderson is also a good choice (maybe even better than the LM) hope this is useful,kpc0 -
steel boiler
dont forget the dynatherm steel boiler,up to 90 percent eff
available with any burner, direct vent option, positve pressure.available with or without tankless coil.cast iron heads.we have some in my family running for over 40 years... thanks mike..0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
