We met Mae West today
Bill NTSG
Bill NTSG Member Posts: 321
It was a 1950's - 60's thing. Most of the ones that I find were on basement or garage zones that were added later. Just on / off for the pump,no boiler control. It saved the cost of a relay. Trouble is the electricians got the circuit from whatever was closest. Not always the boiler circuit. Be careful when replacing the pump!
  • And I do believe she put on some weight
    I would love to know how much she's pushing now . We had to take this one up a full staircase , with a pie cut step at the top .
    As usual , I forgot to get the real name of the boiler . I just go by the nickname the oldtimers gave her . I guess for her assets in front . This one was a 3 zoner .
  • One of the last WBV boilers
    we will be installing . The customer really appreciated that we moved the boiler as far back as possible , and relocated the domestic expansion tank so he doesn't hit his head , again .
  • Bob W._2
    Bob W._2 Member Posts: 79
    > again .
  • Bob W._2
    Curious as to why your company is switching from Peerless....
    Whats the issue?
  • We are switching from
    Peerless to Burnham boilers . Our parent company started using them a while ago , and they believe they are a better product . I was lucky to be one of the 1st to install a V7 in NYC some time ago , but this Monday will be my 1st V8 . Nothing wrong with the Peerless line though - a very durable product.
  • ScottMP
    ScottMP Member Posts: 5,882
    Now that ....
    Is Broom clean !!!!
    As allways Ron, nice neat job.
    Scott
  • you must be getting
    spoiled working in such large areas, keep up the great work
  • kevin
    kevin Member Posts: 420
    Just curious...
    I did not see any relays? Are they just out of sight or are you doing something different that I don't know about..KPC
  • All 3 zones
    were line voltage . Unless the customer requests new digital thermostats , we keep em the same .
  • kevin
    wow
  • kevin
    wow
    Line voltage t-stats on Hot water baseboard. that's a first for me to see that ! Nice clean job Ron. It will be neat to see some of your jobs w/ V-8's kpc
    Steamhead Member Posts: 18,211
    That might be an old Johnson (S.T. Johnson that is) boiler
    they made quite a few round ones with that general appearance- basically a vertical water-tube steel boiler.
    Consulting
  • Just about every boiler we work on
    has at least one zone that is line voltage . In quite a few houses , to save a wire they would run 3 wires from the emergency switch upstairs to the boiler - black is hot , white is neutral , and red is thermostat . And I wont even get into the Levitt houses that break the circulator on the neutral side .........
  • Thanks Kevin
    I found out our fist V8 will be a 4 section steamer in a few days . I hope theyre easy to split .
  • Our little trick of keeping the floor clean
    And sometimes getting the floor cleaner than it was , is to leave speedy dry down on the cement while we work . The guys tell me I look like I'm feeding chickens when I throw it down . Thank you Scott , coming from you thats high praise .
  • Dale W.
    Dale W. Member Posts: 42
    Domestic coil
    Hey Ron,
    Nice clean looking job. We don't do many domestic coils anymore. When we do, we're required to install an anti-scald mixing valve. Am I not seeing one here, or don't you guys use them in your area.
    Dale Wegman
  • jerryb
    jerryb Member Posts: 113
    maewest
    Ron, That boiler you yanked out was a V+E steel double coil Paragon Oil installed many in the late 40,early 50's had probly had a hump-back paragon burner in it,took a strong back too hump these two out,nice new job!
  • Big Ed
    Big Ed Member Posts: 1,117
    Paragon
    Yep , Paragon....called a May West or a Dolly Partton depends on the age of who is asked. Also called a"one hole Paragon" . Because of there is only one tube that you can clean from the top . You have to clean them through the fire expection door(the size of a 4-arm). You need to shove your arm in to the fire box with a brush and clear the outer edge flue passage. Dirty job as well as a service problem . You can't(but we all have in a fix) clean them when they are hot.
    The Dolly Partton was build like a brick Sh!t house , They were made of thick boiler plate. I never seen one leak on it's own to this day . The coils were flanged bolted . And the design was way ahead of it's time. They were a very efficant boiler , but way too tight for the low speed burners at that time.Thank God for the AF . .... The boiler also had a neat built in expansion tank . But if the coils are used you needed to install a ceiling tank , then the built in expansion works like a air scoop. Dumping the collected air back into the tank.....
  • Big , open basement
    to work in this time . Even had an outside staircase . 2 good pluses for this job . The bad part was we had to go across about 75 feet of grass on a down slope , and the top of the stairs ended at the chimney , so they put in a pie step to go to the left around it . There were 3 of us big guys pulling the boiler , and even the customer helped for that last step . Thanks Murph .
