Galvanized condensate recievers? Yes/No?
Jim_2
Jim_2 Member Posts: 3
What are your thoughts on galvanized (hot dipped) condensate recievers?
I have herd aggresive condensate can cause pinholes in the coating, causing it to peel off. Any coating that peels off will be a problem for the pump impeller.
JTM
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,634
    I've never
    seen the need for galvanized.
    Retired and loving it.
  • John@Reliable
    John@Reliable Member Posts: 379
    Gal tank
    Took one out after 15 years of service due to leaking,cut it apart just to see. Found above water line like new,below water line was like pulling a boat out of the water after 15 yrs things were living in there,looked like the surface of the moon but brown instead of green.
