Galvanized condensate recievers? Yes/No?
Jim_2
Jim_2 Member Posts: 3
What are your thoughts on galvanized (hot dipped) condensate recievers?
I have herd aggresive condensate can cause pinholes in the coating, causing it to peel off. Any coating that peels off will be a problem for the pump impeller.
JTM
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,634
    I've never
    seen the need for galvanized.
    Retired and loving it.
  • John@Reliable
    John@Reliable Member Posts: 379
    Gal tank
    Took one out after 15 years of service due to leaking,cut it apart just to see. Found above water line like new,below water line was like pulling a boat out of the water after 15 yrs things were living in there,looked like the surface of the moon but brown instead of green.
Welcome
It looks like you're new here. Sign in or register to get started.
