Steam-Hydronic Conversion
Is steam to hydronic conversion efficient??? Urgent answer please. Thank you very much.
It depends
We'd need more information.Retired and loving it.0 -
More Information...
If we have a straight hydronic system compared to a steam system with heat exchanger and hydronic distribution, which one would be beneficial? Thank you very much.0 -
Are you talking about
a steam boiler with a steam-to-water heat exchanger that then heats a building with hot water? Are you asking for a comparison between that water system and a direct steam heating system?Retired and loving it.0 -
I was talking about a steam boiler with a steam-to-water heat exchanger that then heats a building with hot water and a direct hot water heating system. Which one is beneficial?? Thanks a lot.
Unless there's a static-pressure challenge
such as you'd have in a high-rise building, I see no advantage in using a steam boiler and a converter. I'd just use a straight hot water boiler and avoid the extra equipment.Retired and loving it.0 -
Got the point.
Thank you very much Dan.
- 120 Geothermal
